кто поможет с кодом ошибки?
Автор ICAR, ноября 22, 2006, 19:47:08
ICAR
м40в18 ошибка номер 45. какой из датчиков температуры глючит?
Esculap
DME 1.1, 1.2, 1.3
M20, M30, M40, M70, S38
FAULT MALFUNCTION
1 Fault in the DME control Unit - Reset and run
vehicle if code returns replace DME.
3 Electrical Fuel Pump Relay (EKP)
4 Idle-speed Actuator - Open
5 Tank Ventilation Valve
7 Air-flow Sensor
10 Lambda Regulation
15 Check Engine Failure Light
16 Injection Valve(s)
17 Injection Valve(s)
22 Idle Speed Controller
23 Lambda Sensor - Heater/Air Pump
28 Lambda Sensor
29 Speed Signal
33 Magnetic Valve Hydraulic Automatic Transmission
37 Power Supply
38 ASC/DWA
40 Air Conditioner Compressor
43 Idle-speed Co-potentiometer
44 Temperature-sensor - Air Intake
45 Temperature-sensor - Coolant
50 Engine Towing Moment Regulation
51 Ignition Angle Engagement
52 Idle-speed Switch
53 Wide-open-throttle Switch
54 Torque Converter Lockup Clutch
100 DME Control Unit Final Stage
